vasia
- Apr 22, 2004
Hi guys,
After lengthy considerations, I have gotten Monitor AUdio Silver 8s to go with my Marantz SR8330. Yesterday I have hooked them up using Sound King 12 ga wire and I have couple of questions. I should also mention that I have wall to wall carpet in the living room.
1) The subfloor in my living room is a bit uneven and the speakers are not standing perfectly vertically (not at the right angle to the floor and not quite parallel to one another). The right speaker is a bit tilted to the front and the left is tilted s bit sideways according to the bubble level. Should I use the level and play around with the spikes to try to perfectly level speakers?
2) The bass of the speakers seem a bit tamer than what I remember at the dealer. The speakers do not sound bright, just a bit less punchy. I realize that S8s require long break-in (>60 hr), but I though it mostly tames gold tweeter. Would break-in affect bass as well and in which way?
