Sebastian
- Apr 14, 2002
DIY guys,
I presently have this enclosure using an SVS original driver.
16” sonotube 40” high (approx 44" overall). 1” MDF plugs laminated to ¾ Baltic Birch end caps. 2-1/8" stand-offs and ¾ BB base plate.
Effective volume=5.01 cu-ft, full-length 4" flared precision port from PE giving me an 18.3Hz tune. Pretty much an EBS alignment, It’s within a couple of liters, I believe.
I was thinking on upgrading to an AV-12, what do you guys think? any other options I can look at using with this sonotube enclosure.
Also, would it be worth while to upgrade? I mean what would I gain over the SVS driver?
