BrianShort
- Jan 18, 2000
I normally leave my computer on all the time, but over the past month or two, if I ever left it off for an extended period of time, the computer would fail to boot when I turned it back on. The power light would come on, the fans would spin, and the HDD light would light for several seconds, but otherwise, the computer didn't do anything else. They keyboard lights never came on either. The only way I found to get it to boot was to turn it off, then on again right away. Since I usually leave it on, this wasn't a huge deal.
Well, a couple of nights ago, I got back from gangs of ny, and it looked like my computer was in sleep mode. I moved the mouse to turn it back on, but it reset instead. I left it on during the night, and the next morning, it looked like it had powered down. After getting it into XP, I went to play racquetball for an hour, came back, and the computer was totally locked up. Rebooted buy turning off then on right away, used the machine for a bit, then went to work. Came back from work, computer totally locked up. Rebooted, used computer for maybe 3 minutes, locked up hard. Rebooted. Windows starts to boot, but just before it gets to the XP login screen, it reboots itself. Repeats this 2 or 3 times, gets into windows, I use it for about 2 minutes, then it resets itself again. Turn off computer in disgust.
It's a Micron I purchased 2.5 years ago... I guess it only has a 1 year warranty, and the tech support for out of warranty computers is $2.25 a minute. I asked this in another forum, and a few people suggested it was probably the power supply? Does everyone here agree? I think I may go pick one up today if the local shop sells them, and try that, before messing with tech support.
Hope it is just the power supply, since those are cheap.
Brian
Brian
