Vince Maskeeper
- Jan 18, 1999
Okay, I'm pretty computer literate, so most times I post problems here on the forum, they're way out in left field and all the normal solutions have failed to work. With that in mind, I figure it's unlikely anyone will have any ideas on what to try here, but figured I'd throw it out and see what happens.
I got a Matrox G450 dual head AGP video card from Newegg. My system is currently based around a Epox EP-8KHA+ with 768 megs of ram and a Athlon XP1600 processor. The system has only 2 PCI cards, a Linksys NIC and the Echo Audio Gina 24 studio audio card. Previously it was perfectly stable running an ancient Hercules AGP card, and before that this basic mobo config (with different PCI cards) ran the PC in my Home Theater with a Radeon 7500LE, and also worked just fine.
I installed the card, and immediately noticed system instability. The system was running on an install of Win98 that was reasonably new, so the system would previously boot very quickly. With the G450 installed, the system would hang on hourglass as soon as I logged into Windows. Eventually, tagging Ctrl-Alt-Del to bring up a task list showed "MSGSRV32" as not responding and killing it would free the system up.
However- trying to launch any application would yield the "There is not enough free memory to execute this, quit programs" message (which nothing was running and the system has nearly a gig of ram). Even right clicking on the desktop and picking PROPERTIES yielded an error "The program this link refers to is not longer valid".
Something was obviously in bad shape. My first thought was removing the SETI@Home client, which I set to screen saver only- but it was software recently installed and something which I didn't completely trust. So I removed, and restarted. No luck- same problems with slow restarts, hangs, MSGSRV32 errors, etc.
Since I have had my Echo Audio card be fickle in the past, that was my next thought. Although doubtful, since it loads a mixer application at startup (which was also giving insane error messages I had never seen, including telling me it couldn't find certain paths on F:, which is a CD drive it should never be accessing)-- I thought I should get the most recent driver for this hardware, just to be sure.
I went to the Echo website for the driver- and POP, the computer restarted. No errors, no messages, just a instant restart!
After the system restarted, a few more attempts resulted in the same thing. After a little bit of experimentation, I discovered (get this)--
Any time I visit a website which features Macromedia Flash content, my computer will hard restart or go into a "standby" mode where all the physical hardware is still getting power, but it is no longer posting video!
The menus on the echo site are flash based (http://www.echoaudio.com/menuframe.htm), and if I went to the flash into on the Home Theater Forum- it would also result in a hard restart or this "no video" standby. Basically- the card seemed to go nuts. I have the most recent version of IE, and the most recent flash plug in (I thought about trying to double check about the flash plug in, but the Flash website has flash content which will restart the computer!!)
All the while, the system stability issues were still horrible-- with MSGSRV32 not responding, and applications claiming they didn't have enough mem to run (only to work a few seconds later).
So, I went through the usual suspects:
- I got the Echoaudio drivers for the Gina24 using another PC on my network, and installed the most recent driver for the audio card, no change.
- I tried disabling all the possible features of the Matrox card- disabling the taskbar icon and the other non-necessary features (I had never yet enabled dual head at all!)- no change.
- I tried getting latest drivers from matrox. Removed the original stuff using their uninstaller, and reinstalled the matrox drivers- although the system stability wasn't as bad (I wasn't getting as many system hangs on startup)- but the Flash restart problem continued-- and I started getting a new weird issue where the screen goes back and says "A windows protection fault has occurred, you will need to restart your computer." Overall, no real improvement.
- I remembered reading about a problem with the early EPOX 8KHA+ boards: some would go into a mode where they would fail to POST, and would supply no video. (Here's a note on this: http://www.overclockers.com/tips710). Although I had never had this problem (and it seemed to be something which would happen on startup), I went ahead and got the newest version of Bios and flashed the system. This provided no improvement in the matrox stability issue.
- I figured, although I removed the Hercules drivers, I might still have issues with pieces remaining in the system somewhere. So I bit the bullet, formatted the drive, and reinstalled win98SE fresh. I installed only the Epox VIA drivers, followed by the Matrox Drivers (most recent from the website), followed by the NIC. With no other software, no Echo Drivers, bare minimum system with OS-- and the system stability is still bad, and the system STILL reboots or goes into a no video standby any time I access a site containing Flash content!
- As a last result, I tried pulling and re-seating the Matrox card-- but the performance seems identical.
I'm about to reinstall the old Hecules card, and I'm pretty sure I'll find that the system stability is back to fine. I'm wondering if this is likely a bad G450 card so that replacing it with another will fix it, or if is simply a case of the pieces of hardware in my system simply don't like the Matrox card- so none of them will ever work.
Any thoughts?
-Vince
Any thoughts?
-Vince
