Wendell
- Jul 23, 2002
Can anyone tell me if I have to set the channel levels for each surround mode? I know that on my marantz this was the case, it has different levels saved for dd and dts by memory. The H/K manual doesn't really help that much. I set up using 75db pink noise with a db meter.
If there is different channel level settings saved like the Marantz on the H/K than how would you do that since the channel levels can only be set using the on-screen-display. i had to play the disc and check the levels with a db meter then shut the disc off and go the osd to make adjustment and check the db levels again, I had to repeat this a few times until I had all levels set correctly.
I did try using the ez-set but I felt that the channel levels were off and it didn't sound right. After setting it up manually, it was like WHOA!!!, what a big difference.
Thanks for your help!!
