EricRWem
- Jun 4, 2004
- Adrik
http://www.avsforum.com/avs-vb/showt...93#post4247193
A friend of mine really is looking for help with this. I'll copy and paste his words here.
Just bought a BenQ 8220, and I couldn't be happier with it, but I'm seeing what I can only describe as "grain" in black, or dark, areas of the screen. I'm sure there's a technical term for it, but it looks like film grain to me. It's like crawling dark green dots that show up in any dark area of the screen, if that makes any sense to anybody. My Zenith 318 DVD player hasn't arrived yet, so I'm using a modified Xbox (for progressive scan playback) and the cheap component cable that came with the Xbox HD adapter. I'm thinking it might be the cheap cable, but I really have no clue.
Also, if anybody knows how to access the service menu on the 8220, I'd appreciate info on that, as well.
Thanks.
P.S.
Now that I've seen it, I can't NOT see it, you know? It shows up on s-video, too, where it's much worse. Tried two different DVD players, and three different component cables (none of them expensive ones) and it always shows up. It's only on black, or solid, very dark, areas of the screen. If it's showing up anywhere else, I can't see it.
Thanks.
P.S.
