Thira
- Mar 26, 2003
I just added an addition to my home which included a media room. When the room was built, I had an antenna mounted in the attic of the two story addition. A Harmon Kardon TU-930 AM/FM Tuner is connected with the antenna. THe antenna was purchased at Radio Shack & is for HDTV an FM reception. It is a full directional antenna. The flat brown wire runs from the antenna to the tuner.
I am very disappointed with the reception.
FM is used when I work outside in the yard or relax in the pool. I occasionally use AM during football season. BTW, is there a way to increase the reception of AM for at night reception from distant stations in other states? I do use internet for this but it would be more convient with the tuner.
Thira
Thira
