FM Signal Boost (1 Viewer)
KE1962
Kevin
The tuner in my home theater receiver does not have very good reception. Are there any FM antenna systems or other types of signal boosters that can be set up inside the house (no outside antenna) that provide significant improvement to the FM signal? Thanks.
Tracy R.
Tracy R. Crider
You may want to consider using a splitter from your cable or dish and put a connector on it and use that as an antenna. I have an old dish that I don't use anymore, but it makes a great FM antenna.
NHCondon
