Radeon All in Wonder question...Anyone have this card?
Discussion in 'Computers' started by DeathStar1, Jan 20, 2005.
  1. DeathStar1
    DeathStar1 Producer
    Dec 28, 2001
    3,267
    http://shop.ati.com/product.asp?sku=2484683
    I was looking at this product and noticed that it now comes with a built in FM Radio Tuner.
    With this included, I can finally move my stereo elsewhere and get rid of a whole bunch of wires. Plus more easilly record my favorite radio show...
    But I have one question. How good is the reception on this radio, and can it be adjusted if it comes in fuzzy? If my stereo isn't in the right place, the reception is terrible...but at least I can adjust it.
    Thanks for any help.
  2. Karl_Luph
    Karl_Luph Supporting Actor
    Apr 5, 2002
    974
    I would have to guess that the card has a antenna input on it. Proper position of the antenna would take care of fuzzy reception right?
  3. ChristopherDAC
    ChristopherDAC Producer
    Feb 18, 2004
    3,729
    FM is in the same band as TV. The signal will come in just fine from your TV antenna. Of course I'm assuming you have one connected, to use the TV tuner feature, and you're not using CATV which overlays a bunch of TV channels on that bandspace.
  4. DeathStar1
    DeathStar1 Producer
    Dec 28, 2001
    3,267
    We did have a TV Antenna on the roof, but we hadn't used it in years, and was just recently taken down. But, I'm always using CATV for the TV Tuner feature..
    So this means that unless I have an antenna of some sort, that the FM feature won't work, or is it more like a Walkman in terms of reception?
  5. ChristopherDAC
    Feb 18, 2004
    3,729
    I wouldn't expect it to work at all, no. Even if it had a separate connector for an FM antenna -- which it probably does not, although it may have 2 TV inputs, one for CATV and one for broadcast -- without something attached to it that F connector won't pick up a signal. Now, I once used a paper clip as an antenna to pick up a station, because I was directly underneath its tower, but you won't be able to do that I imagine!
  6. DeathStar1
    DeathStar1 Producer
    Dec 28, 2001
    3,267
    Hmm, If it does require an antenna, are there any mini antennas I can buy and attach to it?
