Jason->D
- Jul 7, 2005
so i just bought a yamaha rxv750 receiver and am looking at speakers to match and am currently considering the following for speakers
either
paradigm with a set of titans up front and atoms as rears with either a cc170 or 270 as a center and then a paradigm sub
or
fluance sx-htb with a sub (undecided as of yet)
my major concern is that although the paradigms will most likely sound much better is are they worth spending the extra $400 for speakers alone or would the fluance be a better choice for someone starting off in ht
if i do go paradigm it will be piecing together 2 speakers at a time until i get money for it all as opposed to the fluance where i could go for it all at once.
just wondering if anyone here has used both and if there is a noticeable difference between the two
this will be used in my basement where i'll be moving it's maybe 10' x 30' (another thing one of the people i was talking to is that the paradigm setup would be underpowered for this size of space)
thx in advance
either
or
thx in advance
