RodC
- Feb 8, 2001
Thanks in advance for anyone willing to make the attempt to read and understand my tale of woe below. Most of this may be unnecessary background info, but after a string of unfortunate events, I'm hoping to possibly uncover the culprit, and recover some data, as well. Over the past month, I've had a string of bad luck with 3 external hard drives (all Maxtor, FWIW, of various capacities.) One of the drives is formatted NTFS, the other 2 HFS for MAC use. I run the MAC DRIVE software on my PC, to allow me to move the HFS formatted drives between the PC and MAC platforms, and still be able to write to them. The drives are connected to a USB hub, so all I need to do is disconnect and reconnect one cable to the hub, to whatever machine I am working on, and it will have access to whichever drive I need that is connected to the hub. I try to make a point of dismounting them from my MAC and safely removing them from my PC, properly. In haste, every now and then, I would goof, and get messages about improper removal. Right before the problems began I lost connectivity to my wireless network. Quickly came to realize that my router had been reset back to factory defaults. Odd, but no big deal. As well, the oven or the microwave settings needed to be reset, too...so I am thinking this was relative to a power surge or the like, and possible cause of problems below. So, all that said, the problems begin...
The first to go, seemed to start exhibiting problems as if the file system was compromised, I was able to copy off much of the data, and reformat the drive with little resistance. I've been reluctant to use it too much, since I am not certain if the format corrected issue (150g Maxtor II, I think.)
The next drive to go (500g Maxtor III,) started by giving me errors when copying music to my iPod. Initially, I thought it might have been my iPod, that is, until the drive began to make the dreaded click-of-death. As such, the drive now appears to be unrecoverable and is out of warranty.
Soon after, I thought I would copy the contents of my ipod to yet another external hard drive, to try and recover as much of my iTunes library as my iPod contained. Unfortunately, the entire library is not on my iPod. (80g iPod versus about 150g data) Went to connect drive #3 (Maxtor One Touch IV, 750g) Now this particular model, does not have an on/off switch on the enclosure, so I plugged it in to power it up. I can here the drive begin to spin up, then there is a click, and then it sounds like it's powering down. At no point does it get far enough into it's power-up cycle to be seen by the computer. Here is my quandry....the drive is under warranty. But based on this minimal activity does it sound like it is the drive? Or perhaps the enclosure itself. If it's the enclosure, I can pop the drive out and connect it to another machine as a secondary drive, BUT at the cost of voiding my warranty. There is a chance I will get the drive out, and find that it is the drive, in which case, not only will I have lost even more data, but voided my warranty and eliminated the possibility of a replacement drive.
So a couple of questions... given the behavior of this 3rd drive, any reason to think, that since the drive does not sound like it is powering up completely, that there may be a shot at recovering the drive at the expense of voiding the warranty by removing it from the enclosure? Part of the problem is that the drive failed with no warning, and I am desperate to remember what was on there.
Any reason to think the problems are as a result of how I am using the drives connected to the hub, and in between machines of different platforms?
I'm at a loss, literally.
Thanks for reading,
Rod
Thanks for reading,
Rod
