Stephen Dodds
- Aug 29, 1998
When EQing stereo subs should you do each one individually, or have the same settings for both?
Steve
Steve
According to what Wayne say, I think that if you want to place your subs at different locations (one left, one right) it will be best to send tone signals to both, simultaneously, and measure the output at your listening position. When you'll finish measuring, you'll have a graph which will show both subs working together. After this, you should apply the EQ to flatten this graph. (you'll have to use an EQ device which can work with two channels simultaneously)
No, you need to test and EQ each one seperately, then fine-tune the settings running both simultaneously.
Actually, having so many subs is not a good idea. However, I 'm getting off to work, so I won't have time to address the issue until later.
