Chris Lehner
- Oct 17, 2002
I'm planning on adding a pair of ADP-170s to my system. I've read a little about the placement of dipoles, but I'm wondering if my room will be a problem. I can only mount them slightly behind the listening position, but what really concerns me is the distance to the rear wall. I only have a section 26" wide. If the width of the 170 is 10", as reported, and I mount them in the center, that only leaves 8" to the rear wall. I know it's not ideal, but is that just way too close? If I move the speaker to the furthest edge of that section, if gives me 16"...better? Of course then the first surface by the speaker would be the sliding-glass door, which is what limits that mounting space to begin with. I think I would really prefer the sound of dipoles, but given my situation should I just go with forward-radiating surrounds?
CDL
CDL
