Dan Hine
- Oct 3, 2000
are you saying i can use any three dimensions as long as they equal the 1.82 cubic foot total?But be sure to use the INTERNAL measurements though. For instance, if the box measures 12 x 12 x 12 then the inside volume is really 10.5 x 10.5 x 10.5 (assuming you're using 3/4" material). Be sure to also account for bracing and driver/port/amp(?) displacement.
