Hopefully, I can do this without calling an electrician.
I need to change from a dimmer to a two pole light switch
First question: After I turn off the power, how do I disconnect the two black wires from this box on the back of the dimmer? Do they just pull out? Is there a release anywhere?
Next, I am hoping I only need those two black wires to connect to the light switch (all the other wires are tucked away inside the wall
This is where it gets tricky...
Do I only need those two black wires and do they get attached to the switch as indicated by the blue arrows? Does there need to be a grounding wire on the other side? There was none attached to the dimmer
