Martin Jiang
- Jul 13, 2000
I am using a malata 520 DVD player as a single source for both video and audio cd. I am very satisfied with its video quality but I have no way of knowing whether it's audio quality is good or bad.
The way I see it, CD is digital. if I use the digital out of the player and send it into my receiver. Then it's using the D/A converter in the receiver, in this case no matter what kind of crappy player I use, as long as it has a digital out, they should all sound eactly the same. Am I right? DO I need to upgrade to a dedicated CD player?
