Sally E
- Nov 23, 2003
I am trying to hook up a Pioneer DV-563A to my Yamaha rx-v1300 receiver using a optical audio digital out. That works fine, however the pioneer manual recommends also connecting the dvd to the receiver using the stereo anaolg connection "for compatability with all disks" When I try to connect the analog out to the receiver (only one output on the dvd for analog) I no longer can play the dvd sound through the tv. I have a high definition tv with plenty of inputs and outputs but can't seem to fiqure out how to do it or if I even need to bother. The yamaha manual doesn't address this issue. I am also running a hdtv sat through the tv with digital optical audio only to the receiver. I am hooking this up for the first time and open to any and all suggestions since I am new to all of this. Thanks for any help you have.
