anand_narayanan
- May 10, 2005
Hey folks,
I recently bought the Onkyo HT-S777C HTIB. I am totally happy with the receiver and speaker system and the sound is amazing. The DVD player that comes with it though has problems. Please check the specs of the DVD player on the onkyo website.
Problem is described below:
Setup : I have hooked up the DVD player that comes with the HTIB (DV-CP702) to the Panasonic PT-AE700U projector and have a screen size of approx 150" or more. What I see is that the picture seems to have some horizontal scan lines at all the edges of objects on the screen. In other words, boundaries of objects (like people) on the screen are not clean, but have zig-zag patterns due to these lines. Is there any way I can get rid of these annoying lines? The picture quality really suffers because of this.
Just to clarify that the problem is indeed with the DVD player and not the projector - I also have an older Toshiba progressive scan DVD player which I wanted to replace with this Onkyo DVD player. The picture that comes out of it to the projector is breathtaking to say the least.
I tried fiddling with all the progressive scan and interlacing modes and the scan lines didnt go away through that. I called Onkyo and they told me that "It was not meant to work with that huge a screen". Can you believe that? I think the customer support guy didnt know what he was talking about.
Any advice or pointer to the problem will be appreciated. If I dont solve it I am selling this DVD player :frowning:
Anand
Anand
