perry web
- Dec 6, 2003
I was going to build a 120L downfiring sub w/ 3.5-4" of space between the bottom floor but I am concerned w/ droop/sag of the woofer over time. I decided to go side firing but do not know how to protect it. I do not like the fabric look and do not want to leave the driver exposed (kids/dogs/drunks)
I have seen downfiring subs that have a piece of wood mounted on the bottom of the legs. Could I do some thing like that for a side fire? I was thinking I could use 4-6 standoffs 3.5-4" long then mount a piece of wood to the standoffs. I would have a piece of wood protecting the woofer from direct damage. what do you all think?
I can not direct link yet so cutnpaste and put www in front
dodgetrucks.org/cgi-bin/index.pl?photo=10810
Also, if you can tell from this pic I am playing w/ the idea of rubber isolating a top piece of wood so I can use this as a end table w/o my jackncoke rattling off the side.
thanks
thanks
