Jay Mitchosky
- Sep 6, 1998
Does a heat shrink product exist to terminate as a Y-end, specifically for speaker cables? Idea is a 1/2" tube that merges into two 1/4" tubes (2:1 ratio so finished would be 1/4" and 1/8"). You could trim to taste, with the larger section going over the main cable with the positive and negative wires slipping through the separate 1/2" sections. Would make for a very clean custom termination.
ADDENDUM: I found a 6:1 style here:
http://www.skycraftsurplus.com/index...ROD&ProdID=717
They also have 4:1 and 3:1. Have left an e-mail re: 2:1.
