Colin Dunn
Right now, I'm projecting onto a wall. A search here and on AVS Forum yielded a lot of stuff about DIY screens, but I'm not sure what's best for my needs ... hence this post.
I'm using a Sony VPL-W10HT LCD projector.
I originally planned on attaching trim pieces to define a 16:9 rectangle on the wall, and paint that trim in flat black.
Then inside the screen area, paint with the Behr Ultra-White paint described over on the AVS Forum.
But then I read that these paint-based screens don't have sufficient gain to use with the 10HT. There was some talk of gray paints, to get the benefits of a gray screen, but again - not enough gain for a 10HT.
The "ideal" option is one I can't afford - a Stewart Firehawk screen. I wouldn't be surprised if that screen, in a 120" 16:9 format, would cost me more than the projector did!
Then there was a dizzying array of other options:
- A guy who goes by "KBK" selling a proprietary "screen goo," a paint formulation with some sort of reflective particles suspended in it. I'm not sure it can be applied to a vertical surface like a wall, though.
- Certain plastic wall materials, often used in constructing bathrooms, being used to yield a flat white screen surface. But these weren't available in 120" 16:9 sizes, and are not as pure of a white as the Behr paint.
- Screens made of white "blackout" cloth stretched over a wood backing.
Any suggestions on what I should pursue? Should I stick to my original plan, paint with "screen goo," or start saving up for that Firehawk???
