Tom.S
- Jul 8, 2002
Does the OSD work on the component video outputs? Thanks.
3)Any HDTV or Progressive signals are "RUMORED" to allow absolutely no on-screen menus. Supposedly the on-screen menus are produced in 480i NTSC format and therefore are incompatible with Progressive or HDTV signals.
I don't know about the 3803, but on the 5803 if I press OSD when feeding progressive component input, the receiver switches into the black screen + OSD display and the output is indeed in 480i.
I can verify that on the 3803 also. It stands to reason a progressive image or a 1080i image will not be compatible with a 480i image. The OSD would have to be output in the format sent over the component cables. Since there are many (myself included) who do not like the low res/very plain and blocky OSD in the first place, putting that on top of a beautiful 480p or 1080i signal would be cheap looking. I don't every really need them except when I am changing parameters. If you can't see what surround mode you are in on the front of your receiver,you can always hit the "surround" button to find out what signal is being sent. But, like said, this will switch to an all black screen with white letters.
