peter a
- Jun 18, 2002
hi-
i was looking into the following system
axiom m80s (main)
axiom vp 150 (center)
axiom m2tis (surrounds)
svs 20-39 pci
receiver: onkyo 898 vs. denon 3802 vs. yamaha rxv 3200
the yamaha can be set to run at 4 ohms, which is great becaue the m80s are 4 ohm speakers. i think the denon can run at 6 ohms, possibly the onkyo as well. question: if i'm running at 6 ohms, will the receiver have any problems powering 4 ohm speakers? i think the surrounds are 8 ohm speakers... will it be a problem combining 4 ohm and 8 ohm speakers on a receiver set at 6 ohms??? thanks in advance.
peter
axiom m80s (main)
svs 20-39 pci
peter
