Hanzabam Naocha
- Oct 12, 2016
- Naocha
Hi,
I am planning to built a dedicated home theater which has already included in my house plan. A room of 18 by 12 (foot), the height being 9 ft, is kept reserved. My budget is 2.5k (only for most of the stuffs such as Projector, AV receivers, Projector screen, speakers and not for ambience related expenses which have already been included in my housing budget). I am thinking of a 7.1 surround sound with in-wall speakers installed. My desire is to have an acoustically transparent screen. My queries: -
1. Which blu ray player should i buy ( I can spend another 800 bucks not included in the above budget)
2. Considering that my room will be pitch dark, which projector should i buy. I am not too much interested in 3D projectors.
3. Regarding the transparent screen, from where should i buy and how much it will cost aprrox.
4. Advise one bestbuy AV receiver.
5. A 7.1 sound system my money can get. (i dont have problem installing speakers and sub-woofer of different companies)
6. Will i be able to play movies using my PC/laptop through the AV receiver via HDMI cable.
That's all.
Thanks and regards,
H Naocha
That's all.
Thanks and regards,
H Naocha
