David Berry
- May 9, 2002
What products do you use to clean CDs? Currently, I just use Sunlight dish soap and clean hands, however, it is time consuming. Any inexpensive product recommendations?
Three sprays and wipe in a circular motion. You think I'm nuts...yup!
realistically i suspect mike is right. unless you're using sandpaper it's probably not an issue.
but i'm not gonna take that chance.
also, i heard you really shouldn't use any detergent type solution? i definitely feel that dish soap is probably too harsh a solution - if you must use detergent, try something milder. or at the very least use a diluted mixture.
but i'm not gonna take that chance.Well, I use the Lenscrafter fluid and wipes (the ones that look like a box of tissues) on my glasses every day. No scratches after two years. That's over 700 wipes in a circular motion with more pressure than I exert when I clean a CD. I really don't feel like I'm "taking a chance".
Oh, yeah... My glasses have anti-reflective lenses which are the most delicate and prone to scratching.
-Mike...
