Steve Schaffer
- Apr 15, 1999
- Steve Schaffer
My ex-wife's 94 Nissan Altima never had warped rotors, nor has my present 01 Sentra.
Most common cause of warped rotors is uneven torquing of lugnuts when the tires are rotated or replaced.
Always request that the wheel lugnuts be hand torqued or that a torque limiting device be used if an air wrench is used to install the lugnuts.
Don't know about other makes but Toyota will warrant any brake problem except pad wear for 3/36. In a few cases we've found excessive pad wear due to misadjustment of the brake booster actuating rod and warranty did covered pads in those cases.
Aftermarket parts negate the warranty only if the part in question caused the problem.
An example would be the popular oil-impregnated K&N air filters. Oil droplets from these can foul the hotwire airflow sensor and this will not be covered by warranty.
Had a Tacoma with a heavily modified exhaust system in the other day with the owner insisting a rattle from the exhaust system be repaired under warranty--no go on that one.
Most common source of problems with aftermarket stuff is electrical malfunctions due to alarms and stereos.
