dadoftwowinds
Grip
- Jan 31, 2010
- John
[COLOR= black]there are many posts on building your own screen... i scored a brand new pull down screen from an auction from which I plan to harvest the screen from and place in a frame. The good news is the screen is exactly 8 ft wide which is the size I want. The bad news is the screen is exactly 8 feet wide.[/COLOR]
[COLOR= black]The link below seems to provide a pretty decent set of instructions for building.[/COLOR]
[COLOR= black]http://www.buildyourownprojectionscreen.com/frame_directions.html[/COLOR]
[COLOR= black]The problem is that steps 3 and 4 guides the "do-it-your-self" person to stretch and wrap to the back side of my board and staple (pasted below). My material is not "stretchy" -- it is white with a black, rubber-feeling backside. Also, even if I can wrap it around and staple, I do not want to give up the 6 to 8 inches that would required. I want 8 feet. [/COLOR]
[COLOR= black]So, what are my options? Should I use create an 8 foot flat surface with sheetrock, or is that too heavy? If I do create a flat surface, how do i glue the material down without harming it?[/COLOR]
[COLOR= black]Or do I build the frame 8 feet across and 5' 7.5" and just glue it on the edges to the frame? If I do that, how can I make sure it is tight?[/COLOR]
[COLOR= black]And finally, if I do glue, I still want the black velvet trip around the outside edge.[/COLOR]
[COLOR= black]Insight is most appreciated. Thanks to you all.[/COLOR]
[COLOR= black]John[/COLOR]
[COLOR= black]3. To attach the materials, roll out your projection screen material[/COLOR] on a clean flat area. Lay your frame, braces facing up, onto the material. Measure the center point of 1 of the shorter frame boards. Put a mark on the inside edge of the board (the side with the metal frame braces showing).
Wrap the material around the top of the frame (no need to be tight just yet). Staple the material at this center mark. Now move to the shorter frame board directly across from the one you just stapled. Measure the center of this frame board as you did the previous board.
Wrap the material around the frame and stretch the material so it becomes tight. Staple into place. Do the same with one of the longer frame boards, and finally the longer frame board directly across from this one. When you're done this, the material will have a diamond-shaped stretch pattern to it.
[COLOR= black]4. Choose a longer frame board. From the center mark where you stapled, move about 3 to 4 inches to the right. Stretch the material by pulling it over the frame and to the right as you do so. Staple into place.
Now move 3 to 4 inches to the left of that same mark on that same frame board. Pull the material over and, this time, to the left as you stretch it. Staple into place. Repeat this back and forth method until you've stapled the material[/COLOR] to the length of this frame board.
Now do the same on the longer frame board directly across from this one. Then do the same to one of the shorter frame boards, then do the shorter frame board directly across from it. With those, you may have to work sideways. The frame will be too tall to work with standing on these ends.
