Mikey.S
Grip
- Oct 26, 2002
ok ive ordered my ht setup
yamaha rx-630rds
toshiba sd220 dvd
mission m72 cinema speakers (5 speakers)
missoin 70as sub
im still a bit confused by the bi-wiring of the 2 main front speakers.
ok the m72 main speakers have 2 sets of binding posts and are rated at 8ohms along with the receiver output rated 8ohms. how do i wire up the outputs of the reciever to the speakers??
if i wire to both sets of posts will it change the impedance??
i dont want to cause problems running everything off its spec.
cheers mike :b
yamaha rx-630rds
toshiba sd220 dvd
missoin 70as sub
cheers mike :b
