ENIGMACODE
Hi Gang
I'm an older Yamaha person - just picked up a mint condition RX-V467. Please bear with me as I scroll through the extensive manual. Wondering how/if I can separately adjust the EQ on the mains; (the 2 front channels), and the center channel independently of the other channels? I'm a little confused as it appears the only way to get output to the rear channels is if I specifically select "7 Channel Enhancer" - Is this just an arbitrary term? Because physically there are outputs for only 5 Channels (as in a standard 5.1 set up). Yes there are 'Pre-Sets' for overall tonal adjustment but I'd like to adjust the EQ manually for just the 2 front channels and the Center Channel. I used to be able to do that on my older Yamaha HTR-5835. Thanx for your patience ...
