JeffMcC
Grip
- May 27, 2004
Best Speakers for Long 3200 cubic ft Room
Looking for ideas on what to do/not to do for speakers for a 7.1 speaker set up in a fairly long narrow room. I've posted a bunch of questions on specific speakers, but since my room has built-in limitations (as I have learned...), I guess it makes sense to narrow the field on types then brands of speakers to begin with.
Here's the deal : room is 12' wide and 21' long. Front wall is 3-sided 6'x6'x6' (12 feet across - actually it's the bump out of my foundation for a picture window) The rest of the room is 21 feet deep with the last 7 feet in back having two 8" risers for seating (8" and 16" tall). It's has in wall boxes wired with 12 gauge for a 7.1 set-up. So I'm thinking of towers in front and a GOOD center, 2 wall mount for surrounds, and 2 wall mount for rears.
I'm planning on finishing out with 1" insulshield on front wall, and to ear level on sides and back. Above ear level sides and back with batting. My listening is 50% movies and 50% music (SACDs are cool!)
So, given that it's a long and narrow room what types of speakers would work best? Particulary concerned that I heard front speakers (tower?) should be 1/3 in from side walls - even at only 3' in that leaves me only 6' for screen - if they are right next to it which doesn't sound to good to me.
Types: Thinking full range all around for music makes sense - towers for fronts, a switchable dipole/bipole for surrounds? (Dipole for movies, Bipole for music), and something to match the set for backs.
Brands - completely befuddled since I think I need to get the types above figured out first - then plumb brands that meet the requirements....
Help, Please!!
Jeff McC
Help, Please!!
Jeff McC
