Fernando Chen
- Jun 30, 1997
It was brought to my attention that one could in theory do the following.
If I want to have my sub in the back, can you just hook it up in series to for example, to the rear left speaker and just set it to large while having the rest set to small and have the subwoofer out on the receiver set to off?
Is the receiver smart enough to send all sub 80 hz from all the speakers set to small to the rear left speaker? If this is true, I am an idiot. Never knew that.
I used to think that setting a speaker to large just meant it would send all the frequencies of that discrete channel to that speaker and setting a speaker to small would send frequencies below 80hz or so to a subwoofer connected to the subwoofer out on the receiver. I never knew you could send frequencies of any speaker set to small to all speakers set to large.
Not like I would do this, but it may help me to understand better how bass management in receivers work.
Fernando Chen
Fernando Chen
