Gregory Scott Bass
- Jun 30, 1997
I will add more later...but here is most of it
http://makeashorterlink.com/?X59222562
I plan to replace them at some point with either another superone or possible a paradigm atom. I would like to put audiocenter2's all around but that would be a 2000 dollar investment in surrounds and I don't see that happening lolI also have the audio center 2 great speaker!. I also at one point have had superones on the side/superzeros in the back. It sounded nice but wanted a better speaker (also considered the ac-2s for the side/back but was to expensive). I ended up getting the vs 2.4s and mounted them horizonally with some speaker mounts from rat shack for the sides. I then put the superzeros in the back, mounted on the ceiling 4 ft behind me. Man, what a difference the vs 2.4s on the side made! nothing short of incredible. They match the 2.9s almost perfectly and can be had for cheap. I bought them new (on clearance) for 380.00 for the pair(original retail was 450.00 each!). the vs2.4s are basically the top half of the vt 2.4s but sound almost identical to the ac-2s.
