I have a friend whos Lap Top will just instantly shut down after 10 or so minets of use, I had a simular problem with my PC a few months back. After cleaning the dust off the heat sinks and the fan off the processor it solved my overheating problem. So I was wondering if this could be Her problem also. It sure seems to be hard ware related as it will not freeze it just switches off no matter what you are doing.
Could it need a good cleaning and how do you open them?
It's a Toshiba Lap Top (XP)!
Wes
Wes
