greg_bun
Grip
- May 14, 2003
Are the acoustic research pro II series of a/v cables good?
How did you come to the conclusion they're essentially the same cable as the Master series?I've been an authorized AR dealer for a few years now, and have compared all of their cables. Looking at the spec sheets on both, the color of the cable jacket seems to be the only difference. The Pro series used different cable. The Master series does use better connectors though.
Unfortunately, with the takeover of Recoton's accessories division (ie: AR cables) by Thomson (RCA), getting information or support (or in my case, more product) from AR has been a nightmare. Hopefully, it will be back to normal soon.
