Best connectors for 5.1
Discussion in 'Home Theater Projects' started by Ryan Leemhuis, Jul 6, 2004.
  1. Ryan Leemhuis
    Ryan Leemhuis Second Unit
    Oct 1, 2002
    490
    I was wondering what deal at accessories4less.com would be best for 5.1 connectors. I was looking at the pro II AR composite cables for 9.99 or the dig. coax cables? I was just wondering which would be the best to carry the signal?
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Hi Ryan.
    Are you talking about 6 separate RCA cables to go from a pre-processor to a amp, or the single coaxial-digital cable?
    If you are looking for the coaxial-digital cable, any well-made video cable should work fine. If a brand you like offers both a composite video and coaxial-digital cable - go for the less expensive cable.
    The people who wrote the SPDIF (Sony Phillips Digital Interface Format) requirements had a ordinary video cable in mind. Some less-than-repuitable cable companies then took their $20 composite video cables, put the words "Digital" on the package and sold them for $50+ until consumers learned that there is nothing special/exotic about the coaxial-digital connection.
    (If anything, the digital nature of the signals mean you can use a really cheap $5 department store video cable and get perfect transmission).
    But you are not getting ripped off with a $10-$15 coaxial digital or video cable.
  3. Ryan Leemhuis
    Oct 1, 2002
    490
    no I am talking about 6 separate cables
  4. Rob Kramer
    Rob Kramer Second Unit
    Mar 30, 2004
    435
  5. JohnMW
    JohnMW Second Unit
    Dec 1, 2000
    280
    Six of those AR pro II composite cables for 9.99 will do the job.
