Ryan Mills
- May 26, 2006
- Ryan Mills
Also one other thing I have a set of speakers like these http://www.siliconholler.com/djuggle.../jvc_hcgd8.jpg I have that come off and they sound awesome with the box they came with so I thought maybe I could use them but would they work or be smart to use with my current setup?
I have a 6 speaker HTIB 5.1 system and was curious if it would be silly to either replace my front small ones with these OR add them some how to the mix? Like can I insert the wires of these in with the same spot as the two small front speakers? Or just dont use them at all?
Thanks a million to anyone that can enlighten me on any of this!
p.s. I tried searching the forums before I posted this and no luck.
Ryan
Ryan
