Drew Dockery
- Mar 18, 1999
I don't use MSN myself, but my girlfriend does. I recently upgraded her from MSN 7 to 8, naturally assuming this wouldn't cause problems, and everything seems to work for the most part, but little changes are driving her crazy. Is there any way to revert back to the previous version? If not, here are the main complaints I'd like to try to fix:
1) When you log in, there is a mail icon on the main toolbar that shows the number of unread messages. This is almost always wrong now, but wasn't before we upgraded, any suggestions?
2) The geniuses took the print icon off the main bar, but I doubt it can be fixed.
3) Previously, you could place a checkmark next to all spam, then hit a block sender button to add the senders to the junkmail filter. Now, the only was I can find to do it you have to manually type in each address to block... again, any help here?
Any fixes or suggestions will really be appreciated.
