Daman
- Feb 4, 2004
I have a yamaha htr5790. I have been reading many other threads about using amps with recievers and getting better performance out of the speakers. my speakers are energy connesieur series(7.1 setup). I was wondering if adding an amp to my setup would really improve the sound a whole lot or would it be just a marginal improvement? Should i power the 3 fronts only or the sides and back surrounds also with the amp.. the reciever in itself is pretty decent. If you do suggest an amp would be worth it then which amps should i be looking at within the 500$ price range. Thanks a Ton!!
Daman
Daman
