SidH
- Feb 28, 2002
I am upgrading my home theater system from 5.1 to 6.1, and plan on upgrading the speakers (Energy Take 5's) as well.
The problem: The listening position is a couch right up against the rear wall. The side walls are 3 feet away from each side of the couch. For various reasons (esp. WAF), the surrounds must be mounted at least eight feet up from the floor. The ceiling is 11 feet high.
I am planning to get DefTech Promonitor 100's for the fronts to go with my new Yamaha RX-V3200 receiver. Usage for music vs. movies is about 50/50.
If I was able to mount the side surrounds lower (6-7 ft.), I would go for something like Polk F/X300's that can be switched between bipole and dipole operation. But at 8 ft. high, I'm afraid the higher frequencies would be largely lost.
Or maybe I could go with three direct radiators (Promonitor 100's or 80's). Maybe mount them all up on the rear wall, with the side surrounds aimed at the side walls and the center rear surround pointed up to the ceiling.
A third option would be to get three speakers designed for inside corner mounting (Boston Acoustics Bravos) and put them symmetrically across the rear wall at the ceiling junction.
Yikes, what to do?
Sid
P.S. Marty it's all your fault
Yikes, what to do?
Sid
