Tammie N-S
- Jul 27, 2005
I am doing some renovations and the drywall goes up in less than two weeks. I'd like to put as much as possible in the walls, so I'm trying to quickly put together a home theater plan even tho I have not purchased any of the equipment.
Any advice about how much of the surround sound speaker placement I can anticipate and pre-wire? I'm planning on 5.1
The placement of the T.V. is not flexible due to wall space and window issues. Well, I guess everything is negotiable, but I don't see any other place for it. The wall the TV would be placed against is a brick wall. All other walls will be regular old drywall with paint. As you can see, there is lots of glass: one window seat, two large windows, and an 8 foot sliding glass door. I don't have any window treatment plans yet.
There is a little bit of wall sticking out to the side of where I want to place the TV, because of a post (I drew it on the floor plan, it's annoying but is actually useful because this is where the electrical outlet will be since the TV will be against a brick wall.) This bit of wall would be just enough to block the view from the card table area if I placed the flat screen directly on the wall, so I'm figuring on a stand. At this point I'm thinking 42 inch plasma.
The placement of the furniture is 100% flexible; in fact, I don't even own most of this furniture yet; e.g., it doesn't have to be a sectional couch. The only requirement is the HAF. The husband must have his recliner, and must have a good view of the TV from said recliner. The door shown to the left of where I have placed the recliner can be closed most of the time; it's a passthru to the kitchen (direct line from recliner to fridge .
Any and all suggestions/advice are welcome!
For lack of a better place to put it, the floor plan I have created is at this URL (please add the www; I haven't posted enough to be allowed to insert URLs yet)
cheverlykidscare.org/hometheaterlayout.jpg
Thanks!
--Tammie
Thanks!
--Tammie
