Hi Stephen - what model receiver do you own? Check if it has any pre-out connections in the rear, to connect a poweramp. We can help you determine if your receiver will be a capable pre-pro.
Also, what is your budget for a poweramp? Are you looking for new or used?
hi alon i have a goodmans dvd player with with agoodmans 5.1 home cinima system at the rear of the sub woofer it has 2 blocks of sockets audio input and speaker output i would like 2 improve the suond quality i already have a kenwood intergrated amp thanks for any help you can give stephen
