MarkJMills
- Jul 23, 2002
I'm ready to try my hand at some home construction with a FleXy rack, per TNT. I'd like to make the shelves acrylic, for both aesthetic and practical reasons; despite searching, though, I've not found any advice as to the specific problems associated with making and using acrylic shelves for this design.
I'm also seeking advice about the thickness of acrylic that would properly support various equipment weights -- would 3/8" be adequate for lighter pieces of 10 to 20 pounds, or would 1/2" be more appropriate? What about equipment weighing up to 35 - 40 pounds? 60 - 70 pounds? 1/2", or would 3/4" be better for the heaviest pieces? The rack as planned would have an overall width of 24 inches, with either 5/8" or 3/4" threaded rods inset 1" from the ends of the shelves, thus about 20" centered would be suspended -- I'm concerned about shelf bowing as equipment gets heavier, yet for cost considerations wold like to use the least thicknesses of shelving that I can. Does anyone have any practical experience with these issues?
The rack has grown into a monster; I need room for 7 components of greatly differing sizes and weights, and must leave some room for cooling and component isolation (Navcom and Vibrapod footers and air bases), so I'm up to a minimum of 50" long support rods (and that's without any room for new additional components!). I don't want to go any higher to make access to the top shelf mounted VPI TT easy -- thankfully I'm tall -- and cannot squeeze two racks into the limited space I have available. At that height, are there serious stability issues that should be addressed?
Any advice at all would be appreciated -- and yes, I did email Arnold Cruz, whose acrylic FleXy is pictured on TNT's site, but have not yet received a reply. I'm hoping to order the shelves on Saturday at a local store that does nice work with acrylics, so any advice, especially re: cutting and shaping issues and the thicknesses required for given weights, is needed ASAP.
Thanks in advance, Mark
