Hello..
I am new to HT set up so need some help. I have a A/V receiver which I am trying to use for building HT with a DVD player, a VCR and TV. My receiver has ability to connect with component a/v cables (so does the DVD player and VCR). So I am planning to use those cables.
My problem is my TV is from 1800s :frowning: :frowning: and has only one input which takes cable box type coneection. What I am mean by that is TV has only one input with wire that comes out from cable box or your cable connection from the wall.
What are my options? I wish to connect all my AV components (TV,DVD,VCR) thru A/V receiver. Can I buy some sort of convertor or adapter which can take component cable and on the other side output will be normal cable wire?
I hope my question make sense...
Thanks in advance.
Sunil*N
Thanks in advance.
Sunil*N
