$500 to spend on a TV at best buy what to get ? (1 Viewer)
Jason-Pro
Well ive got $500 in gift cards to best buy. i wana get a 27" TV. think its worth getting a flatscreen over a regular one? i plan on mounting it on the wall. in my bedroom.
i was there today ( half hour drive) and looked at the panasonic and the samsung i think it was. Samsung was like $450 and the panasonic was like $500 i think. are the sonys worth the extra Money ?
just getting a 27" dont want a really big one because my romo is sorta smaller and its cramed with stuff (main reason for mounting it on the wall)
Jason-Pro
by the way i watch DVDS on the widescreen type. so i want one thatll handle that good.
Jason Caudill
Make sure you can find a mounting bracket to support the kind of weight you are talking about. I doubt Best Buy sells one that can do it.
The Sony may be the only one that can do a 16:9 enhanced mode so that may be worth the $50 to you. Jason
Jason-Pro
Yeah i liked the picture of the sony wega the best they are $550. guess ill have to save up a few bucks to get that + the $27 tax or whatever it would be hehe.
theres Tax on TVs rite?
btw this is the TV mount i got
http://www.partsexpress.com/pe/pshow...number=240-776
i probably will make it safter put a nylon strap around it or something. i bought that one cause it was the cheapest i seen + the only one that would hold over 80 lbs lol. them stupid ones that best buy sells only holds 80 pounds and are like $100
Jael
Take a close look at the Samsung TXL2791F (I think thats right, it's the one with 800 lines of res vs the model with only 600). You can find it for around $450. It's a flatscreen. It does the 16X9 "squeeze" for your anamorphic DVD's with a single button on the remote like the sony. If you have a Sams Club near you the AKAI knockoff is available for a very cheap $350 with the same features.
Best of luck!
Members online
ChewyWaffles
