PaulDA
My room is quite dark (only a small basement window that is easily blocked) and because of space limitations and room orientation, the maximum screen size I can use is 50 inches (55 at the outside). I'm in the early stages of researching possible replacement options for my trusty 32 inch SD WEGA analogue 4:3 TV.
My primary uses for a new display:
DVDs
SD TV watching
HD broadcasts are in the medium term, but not for another 2 years or so (not enough HD material, yet, in my area--could change and shrink the time horizon)
hi-def DVD (once the format war is settled and/or universal players of decent quality are available)
If I go with a TV, it will do all of the above. If I go with a projector (will need a pulldown screen), TV watching will only occur if/when I go HD (but if the projector is inexpensive enough, I'll probably just upgrade the display again for HD--either projector or TV).
I watch a lot of old B&W movies in 4:3, so that has to be taken into consideration.
Thoughts?
DVDs
SD TV watching
Thoughts?
