JeffreyMercado
- Feb 1, 2002
I bought this a couple of months ago, the screen is mint. Retail price is $899, I am asking $500+20 shipping and handling. Money Order or Certified Bank Check preferred
LCD Panel
19" SXGA TFT LCD
2 Dual CCFTS
376.32 mm x 301.056 mm Display Area
Display 16.7M colors
Resolutions
1,280 x 1,024 / 75Hz
Brightness & Contrast Ratio
Brightness: 250 nit (cd/m²)
Contrast Ratio: 500:1
Response Time
15 ms (R) 10ms (F)
Viewing Angle
160º¢X (horizontal)
160º¢X (vertical)
Input Signal and Connector
Analog RGB
1.5 M detachable cable 15-pin mini D-Sub VGA Connector
Link TMDS DVI (Digital Visual Interface)
2 MM 24-pin DVI Connector
1 Up 2 Down USB Ports
User controls
Power on/off, OSD (On Screen Display), Contrast, Brightness, Video Level, Gamma, Frame, Clock, phase, Default Size, Native Size, H-Position, V-Position, H-Size, V-Size, Graph/Text Mode Selection, Auto-adjust, Color Temperature, Audio Volume, OSD H-Position, OSD V-Position, Display Mode Detection, Show Firmware Version, and Reset: Basic Setting, Position, Color Temp. Miscellaneous, & All Functions Features
Flicker and Static Free
PNP: DDC1/2B (Analog), DDC2B (Digital)
Less Than VLMF Radiation Standard
Pure USB Hub 1-upstream, 2-downstream
Panel & base detachable
Factory presetting mode: 41
Ergotron Arm Compatible (VESA 100mm)
Audio
Stereo speakers with amplifier (2 Watt /channel)
Earphone Jack
Options
Other stands (desktop & wall-mount)
Power Source
12v/4.16A, External Universal Input AC Adapter
50W Max
Certifications
UL, C-UL, TUV/GS, CE Mark, FCC-B, VCCI, TUV-Ergo, TCO 1999, EPA
Scanning Frequency
Analog: 24-80 kHz (H), 50-75 Hz (V)
Digital: 30-80 kHz (H), 50-75 Hz (V)
Size and weight
With swivel base: 16" (W) x 18" (H) x 3.5" (D)
Without base: 16"x 14.5" x 3.5"
Gross: 25.6 lbs Net: 18.7 lbs
Warranty
1-Year Limited, Extend Warranty Available.
LCD Panel
19" SXGA TFT LCD
2 Dual CCFTS
Resolutions
Response Time
15 ms (R) 10ms (F)
Viewing Angle
160º¢X (horizontal)
160º¢X (vertical)
Analog RGB
User controls
Audio
Earphone Jack
Options
Power Source
50W Max
Certifications
Scanning Frequency
Size and weight
Warranty
