darrell_s
- Apr 23, 2002
Hi, I would like to get some opinions on what my best options are for a new receiver.
I currently have an 8 year old sony system and I am still using the tower speakers that came with it but the receiver is starting to give out. I mostly listen to 2 channel music, probably about 80/20 music/HT and I also need a set of b speakers for a set of small monitors I occasionally use with my turntables while the sound is also playing through the mains and I would rather not have to use a second receiver for the job.
After reading this board for a while and doing some research I recently ordered an Onkyo 797 from J&R thinking it would be a huge improvement over my current setup(at the time I didnt consider the need for B speaker terminals) but once I hooked it up although I thought it sounded much cleaner, I also thought that for music it sounded much too bright and almost lifeless, so I decided to return it. Since then I have not been able to find anything at a reasonable price that seems to fit my needs.
I have read many positive posts on this board about the H/K 520 regarding music reproduction but it doesnt seem to have B speakers and also seems to be rather low on power. Are there any other units that fit the bill or would it be a much better decision to wait and save up to purchase something like the Outlaw 950 and maybe some used amps.
If all else fails I will probably just end up getting something like the Onkyo 700(which will probably be similar to the 797 but with b speakers) and just get used to the sound...
Thanks in advance.
Thanks in advance.
