Dolby True-HD and DTS-HD (1 Viewer)
Steve Tannehill
R.I.P - 4.28.2015
Deceased Member
DFW
Steve Tannehill
A note on Dolby True-HD.
While Phantom of the Opera has the track, it will not play on the Toshiba HD-A1 because that player only handles 2-channel Dolby True-HD, not 5.1 channel. I don't know if the player is complaining about it, or the movie--but the 5.1 track will not play back or downconvert.
Do we want to get into how the Toshiba player converts DD+ to 1536kbps DTS on certain discs, if you use optical/coaxial digital connections and choose bitstream output?
I am not making this up! :)
- Steve
andy wells
Not sure if I did something wrong.. I bought a few audio cables to run an analog 5.1 mix to hear the dolby plus track. I had the cables going from the player to the reciever. When I did the "speaker test" to adjust the volume levels,there was a "white noise" sound from each one, one at a time. oddly this same sound also came from the sub. Is that normal? I expected a low rumble.. I tried playing the movie (serenity) and the bass was nowhere NEAR what it was when I used the digital cable (and bitstream).. I cranked my subs bass up and still was VERY weak. I switched it back to the digital connection and it was the same seat shaking bass I'm accustomed to.. I can't help but think I may have missed something...:b
DaViD Boulet
There is also more than enough talk about this over at AVS. Roger Dressler is even chiming in.
If I get the energy, I'll post some summary points over here to highlight the basic issues (much of what has already been covered here).
papill6n
