Hi y'all,
So, I'm considering getting a 7.1 surround setup. However, I'm not quite sure if it would work with what I'd like, so I'm coming here for some help.
Anyway, I would like to get the following things to make up my system:
Q Acoustics 3000 5.1 System
Denon AVR-S930H
And I already own two Tannoy speakers which I would put in to make it 7.1. Anyway, I have a couple questions.
First, I primarily plan on running the system using my laptop. However, in the audio output properties of the HDMI output, it says the maximum number of channels is 2. I assume this probably means that output will not be able to carry a 7.1 surround output, unfortunately, correct? In this case, is there anything which I could get to connect through USB to run video and audio to the receiver?
And secondly (Though this I don't think will be too much of a problem, as I'm not planning on running anything at super high power), the receiver says it outputs 90 watts, but the speaker system says its output wattage is 540 watts. This seems rather high to me, am I missing something here?
Thanks in advance,
Sasschary
Denon AVR-S930H
Thanks in advance,
Sasschary
