Turntable hum bose lifestyle 28 (1 Viewer)
Earlbear
Earl
I have a fluance rt81 turntable hooked to a bose lifestyle 28 and get a hum at louder volumes, cannot ground the turntable to the bose as it is not metal , any help with getting rid of the hum would be appreciated , Thanks
JohnRice
Bounded In a Nutshell
A Mile High
There aren’t any screws on the connection panel you can ground to? Does that even have a phono input?
Earlbear
Earl
I moved both plugs from a surge strip to an outlet and tha seems to have fixed the hum ! They are both 2 pronged plugs but it seems to have fixed it , I can crank it up as high as I want and am not getting the hum , before it started at around 40 on the volume and I put it up to 70 ( that was all my ears could take!) And no hum !!! :)
mycuu
